The openmapwindow statement opens a window displaying a map of a location.
This statement has seven parameters:street – street address of location. Do not include suite or apartment number.
city – city to be displayed.
state – state (two letter abbreviation).
zipcode – zip code (optional, may be “” or entirely omitted).
country – country of location, however this parameter is currently ignored, only works for United States. You can omit this parameter.
mapheight – height of output map in points (if missing the default is 600).
mapwidth – width of output map in points (if missing the default is 1000).
This statement opens a window displaying a map of a location. The map is zoomable and resizeable. You can open multiple map windows simultaneously, these windows are independent of your database. If a window with this location is already open this command will simply switch to the already open window.
For example, suppose you have a mailing list database that contains US addresses (it may also work in other countries, but this is not guaranteed). You can open a map window with one line of code, like this:
openmapwindow Address,City,State,Zip
When you run this code, a new map window will open.
This map window is separate from the database itself. The map window will not update to a new location if you move to a different record in the database, or edit the address. To see a different address, run the program again to open a second map window.
If you want to display a map in a database window, a map that will stay synchronized with the data, create a form with a Web Browser Object that uses the mapurl( function. But if you just want a quick way to open a map with a single line of code, the openmapwindow statement is very convenient.
10.0 | Updated | Carried over from Panorama 6.0, but default size is now larger. |
