alertcanceldelete
TEXT
The alertcanceldelete statement displays a modal alert window with a message and two buttons: Cancel and Delete.
This statement displays a modal alert window with a message and two buttons: Cancel and Delete. (Cancel is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertcanceldelete "Do you want to continue?"
if info("dialogtrigger") = "Cancel"
stop
10.0 | Updated | Carried over from Panorama 6.0 but does not have 255 character limit, and automatically grows in height to accommodate the specified text. |
