formcleanview
The formcleanview statement cleans up extraneous NSView objects in the current form.
This statement cleans up extraneous NSView objects in the current form. This mysterious statement should only be used when directed by ProVUE Development.
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
10.1 | New | New in this version. |
