propagateup
The propagateup statement fills all the empty cells in the current field. Each empty cell is filled with the value of the first non-empty cell below it.
The propagateup statement fills all the empty cells in the current field. Each empty cell is filled with the value of the first non-empty cell below it. The difference between this statement and the propagate statement is that propagateup scans the database upwards, from bottom to top.
This example fills any empty dates with the date from the next record.
field Date
propagateup
Note: When combined with the fillall statement, the propagateup statement can modify invisible records as well as visible records. See the FillAll statement for details.
10.0UpdatedCarried over from Panorama 6.0, but can now be combined with the FillAll statement to modify both visible and invisible records.
