collapsetosummary
The collapsetosummary statement collapses to the next higher summary level.
This statement collapses an outline from the bottom up. For example, if the current record is a raw data record, this statement will collapse this record and all of its sibling data records in the outline. If the current record is a summary record, all of the sibling summary records will be collapsed, along with any children they have.
- analyzedialog -- opens the standard Analyze dialog.
- average -- calculates averages and sub-averages for the selected records in the current field.
- collapse -- hides the detail records associated with the currently active summary record.
- count -- counts all non-empty data cells for the current field.
- expand -- reveals the next level of collapsed detail records associated with the currently active summary record.
- expandall -- reveals all collapsed detail records associated with the currently active summary record.
- groupdown -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in descending order (high to low).
- groupup -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in ascending order (low to high).
- maximum -- calculates the maximum and sub-maximums for the current field.
- minimum -- calculates the minimum and sub-minimums for the current field.
- removeallsummaries -- removes all summary records.
- removedetail -- removes data records from the current database, leaving only summary records. It can also delete low level summary records, leaving only higher levels.
- removesummaries -- removes summary records from the current database.
- total -- calculates totals and subtotals for the current field.
