extensiontype
EXTENSION
TYPE
The extensiontype statement returns the type code of the specified file (if any).
extension – the extension you want to know about, for example .jpg, .txt, .gif, etc.
type – Field or character where the type code will be placed.
This function returns the type code of the specified file (if any). The type code is a special 4 character codes that identifies the type of the file.
local typeCode
extensiontype ".jpg",typeCode
When this procedure is run, the typeCode variable will contain JPEG
Note: Type codes are leftovers from Mac OS 9 and earlier. They are not used by modern systems.
Common Type/Creator Codes
Here are some of the common type/creator codes that Panorama supports.
Type Code | Creator | Extensions | Notes |
ZEPD | KASX | .pandb | Panorama Database |
KSET | KASX | .panset | Panorama File Set |
TEXT | | .txt .html .css .csv | Text File |
JPEG | | .jpg .jpeg .jpe .jfif | JPEG Image File |
PNGf | | .png | PNG Image File |
TIFF | | .tiff .tif | TIFF Image File |
GIFf | | .gif | GIF Image File |
PICT | | .pict .pct .pic | PICT Image File (OS 9) |
BMPf | | .gif | BMP Image File (Windows) |
PDF | | .pdf | PDF Document (note space on end of type code) |
8BPS | | .psd | Photoshop File |
MOOV | | .mov .moov .qt | QuickTime Move File |
WAVE | | .wav | Audio File |
MPEG | | .mpg .mpeg .mp3 .mpe .mpa .mtv | MPEG Media File |
AIFF | | .aif .aiff | Audio File |
