The matrixclickedobjectid statement helps implement buttons in a matrix object.
This statement has one parameter:objectid – Returns id of object that was clicked on, or 0 if none.
This statement helps implement buttons in a matrix object. It can be called when a user clicks within a matrix to find out which object within the matrix frame was clicked on, if any.
local mButton
matrixbutton mButton
if mButton="Add"
 elseif mButton="Delete"
| Version | Status | Notes |
