newdatabasewithfields
FIELDPROPERTIES
The newdatabasewithfields statement creates a new database with one or more fields.
fieldproperties – dictionary containing properties of database field (repeat for each field you want to create).
This statement creates a new database with one or more fields. You can fully specify the parameters of each field, see the setfieldproperties statement for details.
Here is an example that creates a simple mailing list database:
initializedictionary(
"NAME","Name",
"CAPITALIZATION","Word"
"NAME","Address",
"NAME","City",
"NAME","State",
"CAPITALIZATION","All",
"RANGE","AZ"
"NAME","Zip",
"RANGE","09-—"
Note: This statement is used for restoring database blueprints.
- automaticfieldname( -- returns an available field name.
- copycell -- copies the contents of the current field onto the clipboard,
replacing anything previously on the clipboard.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- formulacalc -- allows you to evaluate a formula that you were not able to
code into the procedure when it was being written.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
