movefieldbefore
FIELD
The movefieldbefore statement moves the current field to a new position.
field – is the name of the field you want to move the current field in front of, or ""
to move the current field to the end (beyond the rightmost field).
This statement moves the current field in front of the specified field. For example, suppose you have a Contact database with fields for Name, Address, City, State, Zip, Phone and Email. This example would move the Phone field in between the Name and Address fields.
field "Phone"
movefieldbefore "Address"
If you want to move the current field to the end of the database (beyond the rightmost field), specify ""
for the before field. This example will move the Phone field after the Email field.
field "Phone"
movefieldbefore ""
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
