The progressbar statement updates a progress bar on the current form.
This statement has five parameters:bounds – name of object that defines the progress bar location and size.
mercury – name of object that grows and shrinks.
temp – Current “temperature”.
boiling – Maximum “temperature”.
inset – Number of points the mercury is inset from bounds (default is zero).
This statement updates a progress bar on the current form. The progress bar consists of two objects, the bounds object (usually displays a background) and the “mercury” object, which grows as process is made.
progressbar "Progress","Indicator",47,150
Note: This statement is retained for compatibility with legacy databases, but for new applications the recommended practice is to use a Progress Indicator Object or Level Indicator Object.
