showcolumns
FIELDS
The showcolumns statement forces Panorama to display specified fields.
fields – is a list of fields to be displayed. Each field name should be separated from the next by a comma. If a field name contains spaces or punctuation, or begins with any character except a letter or underscore, it should be surrounded by chevron (« ») characters.
This statement tells Panorama to redisplay specified fields in the current record in every open window of the current database. Use this command after the noshow command when you have only modified certain fields in the current record. ShowFields does not turn the display back on. To do that you must use the endnoshow statement.
The example below would normally erase and re-display the current record three times. Adding the noshow and showfields statements suppresses the extra drawing. Even though three fields are modified, only the Balance field is erased and re-displayed once at the end of the procedure.
noshow
Date=today()
Time=now()
Balance=Credit-Debit
runningtotal
showcolumns Balance
endnoshow
- automaticfieldname( -- returns an available field name.
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- fontcharacters( -- returns a string (text) containing all of the characters supported by the specified font.
- fontinfo( -- returns a dictionary with information about a specified font.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- hide -- temporarily disables the output of text and graphics.
- measuretext( -- returns the size of a string of text in a particular font and size.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- setbannerprogressbar -- displays progress in the toolbar banner.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showline -- forces Panorama to redisplay the current record in all windows in the current database.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
