The speakscript statement speaks a speech synthesis script created in the Database Options dialog.
This statement has two parameters:database – database that contains the script. If this parameter is empty, the current database will be used.
script – Name of the script you want to speak. If this parameter is empty, speak the default script for this database.
This statement speaks a speech synthesis script created in the Database Options dialog.
speakscript "My Contacts","Contact Info"
