callwithin
PROCEDURE
LABEL
PARAMETERS
The callwithin statement allows a procedure to call a mini-procedure within a separate procedure within the current database as a subroutine.
procedure – is the name of the procedure to call. If the mini-procedure name does not have any spaces or punctuation, no quotes are required. You can also use a formula to calculate the procedure name “on the fly.”
label – identifies the beginning of the mini-procedure. (The end of the mini-procedure is defined by a rtn or return statement or the end of the main procedure). A label is a unique series of letters and numbers that identifies a location within the procedure. The label must start with a letter, may not contain any spaces or punctuation except for ., _ and %, and must always end with a colon. The colon is not actually part of the label, it simply identifies the series of letters and numbers as a label instead of a field or variable..
parameters – is a list of parameters to be passed to the subroutine. This list is optional, you don’t have to pass any parameters if you don’t need to. See parameter( and setparameter for more information on accessing parameters within a subroutine.
This statement is a combination of the call and shortcall statements. It effectively allows you to combine a bunch of mini-procedures into a single procedure.
This example shows how three different mini-procedures within the Calculate procedure can be called.
callwithin Calculate,Total
callwithin Calculate,Tax
callwithin Calculate,Shipping
In the example above, the procedure name and label are fixed, but you can use a formula to calculate either of these, as shown here:
callwithin UserInterface,replace(info("trigger")," ","")
This example assumes that the UserInterface procedure includes labels something like this:
Button.Ok:
    return
Button.Cancel:
    return
Button.NewUser
    return
If the specified label does not exist, an error occurs. You can check the labels in advance with the getprocedureoption( function.
local userTrigger
userTrigger = replace(info("trigger")," ","")
if arraycontains(getprocedureoption("","UserInterface","LABELS"),userTrigger,cr())
    callwithin UserInterface,userTrigger
else
    returnerror userTrigger+" not implemented yet!"
When you call a subroutine, you can supply one or more parameters to be passed to the subroutine (parameters must be separated by a comma). When using the callwithin statement, the parameters are listed after the label name, like this:
callwithin procedure,label,parameter1,parameter2,parameter3, ... parameterN
See the call statement for more information about accessing and modifying parameters.
