The looparray statement is used at the beginning of a loop that loops over the elements of an array.
This statement has four parameters:array – is a formula that calculates the array to be scanned. This could be a field or variable, or a complex formula.
sep – is the array’s separator character.
element – is the name of a field or variable where each array element will be stored. If this field or variable does not already exist it will be created as a local variable.
index – is the name of a field or variable where the loop count will be stored. If this field or variable does not already exist it will be created as a local variable. (Note: This parameter is optional – if you don’t need to know the loop count, you can leave this parameter off.
The looparray statement is used at the beginning of a loop that iterates over a text array (see Text Arrays and Loop more information on these topics). LoopArray loops are always terminated with an endloop statement.
When the loop starts, Panorama calculates the text array (based on the formula in the first parameter) and makes a copy of it. Each time through the loop Panorama extracts the next element from the array for processing. In other words, the first time through the loop the first element is processed, then the next time through the second element is processed, etc. The loop repeats until all of the array elements have been processed.
Here is how it works:
looparray myarray,myseparator,item
... do something with item
endloop
Here is a simple example that loops once for each word in the Notes field.
looparray Notes," ",word
message word
endloop
If the Notes field contains Now is the time, the message alert will appear four times, once for each word.
Adding a fourth parameter to the looparray statement allows you to access the number of times the loop has repeated so far.
looparray Notes," ",word,wordnumber
message wordnumber+": "+word
endloop
Again, if the Notes field contains Now is the time, the message alert will appear four times, but this time each word will be numbered like this:
☞ 1: Now
☞ 2: is
☞ 3: the
☞ 4: time
It’s possible to create a loop that iterates over an array without using the looparray statement. For example, the previous example could be written like this:
local word,wordnumber
for wordnumber,1,arraysize(Notes," ")
word=array(Notes,wordcount," ")
wordnumber=wordnumber+1
endloop
As you can see, writing the loop this way takes six lines instead of three. Using looparray is also significantly faster, especially with large arrays, because looparray uses special optimizations to reduce the amount of processing that needs to be done on the array each time through the loop. In some cases, it may even be worthwhile to rewrite old code to use looparray instead of other types of loop statements. However, unlike other Panorama structures, looparray is not compatible with recursion. If looparray is used inside a procedure and a recursive call to the same procedure is made within that loop, no more iterations of the loop will take place.
Note: If the text array is empty, the statements in the loop are skipped without even executing them once.
Error Messages
LOOP without ENDLOOP – Each FOR statement must be paired with a corresponding ENDLOOP, UNTIL or WHILE statement. If this error message appears, the necessary statement terminating the loop has not been included.
LOOPARRAY element parameter must be a field or variable – The ELEMENT parameter must be a field or variable, it cannot be a more complex calculation.
LOOPARRAY index parameter must be a field or variable – The INDEX parameter must be a field or variable, it cannot be a more complex calculation.
10.0 | New | New in this version |
