modifyfileattributes
PATH
ATTRIBUTE
VALUE
The modifyfileattributes statement modifies one or more attributes of a file (or folder).
This statement has three  parameters:
path – is a path to the file or folder to be modified, including the file name (see Files and Folders for more information about file paths).
attribute – the attribute to be modified (see below). You can use multiple attribute/value pairs, or you can combine all of the attribute/value pairs into a dictionary and pass that into this parameter (in that case omit the value parameter).
value – the value of the option to be modified.
This statement modifies one or more attributes of a file (or folder). For example you can change the creation or modification date, the permissions, etc. You can modify one attribute or several. For example, this code will change the creation and modification date of the Flower.jpg file to today at midnight.
modifyfileattributes "~/Pictures/Flower.jpg",
    "CREATED",superdate(today(),0),"MODIFIED",superdate(today(),0)
An alternate method is to combine all of the options into a single dictionary, like this:
    initializedictionary(
A possible advantage of using a dictionary is that you can package up all the options in advance in a variable.
File Attributes
The primary attributes that can be modified are:
- CREATED - creation date and time (see SuperDates).
- MODIFIED - modification date and time (see SuperDates).
- OWNER - name of the file’s owner.
- OWNERID - user ID number (integer) of the file’s owner.
- GROUP - name of the group the file belongs to.
- GROUPID - group ID number (integer) of the group the file belongs to.
- PERMISSIONS - an integer containing the File System Permissions
There are three additional attributes that quite frankly, we don’t understand. However, these are attributes supported by macOS, so they are included.
- HIDDENEXTENSION - a boolean value.
- BUSY - a boolean value.
- IMMUTABLE - a boolean value.
- foldercontains( -- checks to see if a folder contains a specified file. See also the  pathcontains( function.
