calcenclosingrectangle
FORMULA
RECTANGLE
The calcenclosingrectangle statement will calculate the rectangle surrounding all of the specified objects.
formula – formula for use in selecting objects, or "ALL"
if all objects should be selected.
rectangle – field or variable – the calculated rectangle will be placed in this variable.
This statement will calculate the rectangle surrounding all of the specified objects. This example will calculate the rectangle around all objects in the current form that contain text.
local enclosingRect
calcenclosingrectangle objectinfo("font")<>"",enclosingRect
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
