assignfield
FIELD
VALUE
The assignfield statement performs an assignment, much like an equals sign or the assign statement. However, the assignfield statement only performs the assignment to a database field, not to any variable.
field – is the name of the field that you want to modify.
value – calculates the value that will be placed into the field in the active record.
This statement performs an assignment, much like an equals sign or the assign statement. However, the assignfield statement only performs the assignment to a database field, not to any variable.
The procedure below will assign the value 714 to the AreaCode field – even if there is a variable named AreaCode.
assignfield AreaCode,"714"
- fileglobal --
