createpassword
CHARACTERS
NUMBERS
OPTION
PASSWORD
The createpassword statement creates a random password using characters or numbers (or a mixture) set to the chosen length.
characters – Number of alphabetical characters to use in the new password .
numbers – Number of numeric characters to use in the password.
option – Sets the option for the alpha characters. Using “U” or “u” sets it to all upper case while “L” or “l” uses lower case. Using an empty string “” uses random case for each character.
password – The result is placed in this field or variable.
This statement creates a random password using characters or numbers (or a mixture) set to the chosen length.
This example will assign a 10 digit password to the field or variable called MyPassword containg a randomly mixed string of 7 upper case letters and 3 numbers.
local MyPassword
createpassword 7,3,"U",MyPassword
message MyPassword
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
