clientimportuploaddata
The clientimportuploaddata statement contacts the server to upload and insert new records to the server when importing or appending new data.
This statement contacts the server to upload and insert new records to the server when importing or appending new data. It is used internally by Objective-C methods in Database+Import.m. This statement should only be used internally by ProVUE, it should never be used independently by a customer.
- Web Cookies -- web cookies.
