clipboardimagesave
PATH
OPTION
VALUE
The clipboardimagesave statement saves an image on the clipboard as an image file (.jpg, .png, etc.).
path – the path and filename of the image file.
option – this and the following parameter are optional, and may also be repeated. It specifies an option for modifying the operation of the clipboardimagesave statement. See the text below for details.
value – value of the option.
The clipboardimagesave statement allows you to save the contents of the clipboard as an image file. Of course this only works if the clipboard contains an image, if it contains text or any other type of data, this statement will stop the procedure with an error. This example will save the image in the clipboard to a file named flower.jpg in the same folder as the current database.
clipboardimagesave "flower.jpg"
By specifying a path, the file can be placed anywhere on your disk.
clipboardimagesave "~/Desktop/flower.jpg"
Image Type
Normally the image type is specified by the extension of the saved file – choose from .jpg (or .jpeg), .png, .gif, .tiff (or .tif) or .bmp.
You can also use the TYPE option to explicitly specify the image type, for example:
 clipboardimagesave "~/Desktop/flower","TYPE","TIFF"
The type may be upper or lower case.
It’s possible to create an image file that has a type that conflicts with the file extension.
clipboardimagesave "~/Desktop/flower.jpg","TYPE","PNG"
However, we don’t recommend doing this.
JPEG Image Compression
Images saved in the JPEG format are compressed. Using compression saves disk space, but reduces the quality of the image. Use the COMPRESSION option to specify how much compression should be used. The compression may be from 1.0 (minimal compression) to 0.25 (very compressed). This example saves the flower image with 40% compression.
clipboardimagesave "flower.jpg","COMPRESSION",0.4
If you don’t specify the compression factor, the default value of 0.7 is used. If the image type being saved doesn’t support compression, the compression factor will be ignored.
Image Scale
This statement normally saves the image at the same size it was on the clipboard. However, you can specify a scale factor to reduce or enlarge the image. If the scale factor is less than 1, the image will be reduced, if it is larger than one, it will be enlarged. This code saves the image at half size (50% = 0.5).
clipboardimagesave "flower.jpg","SCALE",0.5
This code saves the image at double size (200% = 2.0).
clipboardimagesave "flower.jpg","SCALE",2.0
If you don’t specify a scale, then 1.0 (100%) is used.
Image Resolution
To specify the resolution of the saved image, use the DPI option (dots per inch). This example saves the flower at 144 DPI.
clipboardimagesave "flower.jpg","DPI",144
If the DPI is not specified, the DPI used by the image on the clipboard will be retained.
Note: Increasing the DPI doesn’t magically create new image data. If the original image is 72 DPI, you can save the image at 144 DPI, 300 DPI, or higher, but the image won’t actually be any sharper. It will, however, take up much more disk space.
Combining Multiple Options
It’s possible to use multiple options at a time, just separate them with commas.
clipboardimagesave "flower.jpg","scale",0.5,"dpi",144,"compression",0.6
As shown above, the option names can be in either upper or lower case, or any combination.
Error Messages
CliboardImageSave error (no image on clipboard) – An image must be copied onto the clipboard before using this statement.
