forcesynchronize
The forcesynchronize statement force synchronizes the local database with Panorama Server (downloads all records, not just recently modified ones).
This statement force synchronizes the local database with Panorama Server. This is the same as choosing Download Data from the File menu (you must hold down the Option key to use this menu item). When this statement is used, all records are downloaded from the server, not just the recently modified ones.
- Web Cookies -- web cookies.
10.2 | No Change | Carried over from Panorama 6.0. |
