getmaxwindow
TOP
LEFT
HEIGHT
WIDTH
The getmaxwindow statement retrieves the position and size of the largest possible window on the main screen.
top – field or variable that will be filled with the top edge of the max window.
left – field or variable that will be filled with the left edge of the max window.
height – field or variable that will be filled with the height of the max window.
width – field or variable that will be filled with the width of the max window.
This statement retrieves the position and size of the of the largest possible window on the main screen. Note: This statement is obsolete, in new code you should use the info(“availablescreenrectangle”) function.
