excludefromrecentmenu
The excludefromrecentmenu statement excludes the next opened database from the Recent menu.
This statement is designed to be used immediately before the opendatabase statement. It tells Panorama not to include the next opened database in the Open Recent menu.
Note: Once you use this option on a database, that database will never appear in the Open Recent menu, even if you later re-open it again without using the excludefromrecentmenu statement. The only way to reverse this is to change the database preferences or to use the setdatabaseoptions statement.
