cancelok
TEXT
The cancelok statement displays a modal alert window with a message and two buttons: Cancel and Ok.
This statement displays a modal alert window with a message and two buttons: Cancel and Ok. (Cancel is the default.) Afterwards, the name of the button that was clicked will be in the clipboard.
cancelok "Do you want to continue?"
if clipboard() = "Cancel"
stop
Note: This statement is retained for compatibility with legacy databases. For new applications, the alertcancelok statement, which does not disturb the clipboard, is recommended.
