crosstabselectoriginalformula
CROSSTABINFO
ROW
COLUMN
FORMULA
DATABASE
The crosstabselectoriginalformula statement returns the formula that will select the original data associated with a crosstab cell.
This statement has five parameters:
crosstabinfo – is the name of variable that contains the crosstab specifications.
row – is the crosstab row that was clicked on (1-N).
column – is the crosstab column that was clicked on (1-N).
formula – variable to receive the formula.
database – variable to receive the name of the original database.
This statement returns the formula that will select the original data associated with a crosstab cell. You can use this to select the original data in the original database, or pass it to another text list or matrix to display the subset in that object.
This example will display the data corresponding to the current crosstab cell in the original database.
let clickedRow = info("matrixrow")
let clickedColumn = info("matrixcolumn")
local selectionFormula,originalDatabase
crosstabselectoriginalformula crosstabInfo,clickedRow,clickedColumn,selectionFormula,originalDatabase
topdatawindow originalDatabase
if selectionFormula=""
    selectall
else
    execute "select "+selectionFormula
10.1NewNew in this version.
