alertoksmall
TEXT
The alertoksmall statement displays a modal alert window with a message and one button: Ok
This statement displays a modal alert window with a message and one button: Ok.
alertoksmall "Done!"
10.0 | Updated | Carried over from Panorama 6.0 but does not have 255 character limit, and automatically grows in height to accomodate the specified text. In Panorama 6.0 and earlier this statement produced a smaller alert than the regular message or alertok statements, but it now adjusts in size automatically the same way these other statements do. |
