getwebtemplate
DATABASE
FORM
RESULT
The getwebtemplate statement retrieves the web template (a dictionary) associated with a form (if any).
database – name of the database that contains the form, or “” for the current database. The specified database must be open
form – name of the form the template is associated with.
result – name of the field or variable the result should be placed into.
This statement retrieves the web template (a dictionary) associated with a form (if any).
local signUpFormTemplate
getwebtemplate "","Sign Up",signUpFormTemplate
An alternate method for retrieving a template is to use the getwebtemplate( function.
10.2 | Updated | Carried over from Panorama 6.0, but now stores the template in the form itself, and allows a database to be specified. |
