lockorstop
The lockorstop statement attempts to lock the current record. If the record is currently locked by another user, the procedure stops with an error
This statement attempts to lock the current record. If the record is not locked by any other users, the code continues normally. If the record is currently locked by another user, the procedure stops with an error.
let ReceivedQuantity=""
gettext "How many "+Item+" were received?",ReceivedQuantity
ReceivedQuantity=val(ReceivedQuantity)
LockOrStop
if error
message "Could not update inventory, try again later."
stop
Qty=Qty+ReceivedQuantity
UnlockRecord
If you want the code to wait for the record to be unlocked, use the unlockrecord statement. If you want complete control over what happens in any case, use the lockcurrentrecord( function.
- Web Cookies -- web cookies.
10.2 | No Change | Carried over from Panorama 6.0. |
