newdatabase
The newdatabase statement creates a new database.
This statement creates a new database. The new database has one field (named A) and one empty record. After creating the database, Panorama opens its data sheet window. This example creates a mailing list database with 5 fields.
newdatabase
setfieldproperties initializedictionary("NAME","Name")
addfield "Address"
addfield "City"
addfield "State"
addfield "Zip"
- copycell -- copies the contents of the current field onto the clipboard,
replacing anything previously on the clipboard.
- formulacalc -- allows you to evaluate a formula that you were not able to
code into the procedure when it was being written.
| 10.0 | Updated | Carried over from Panorama 6.0, but the new database's initial field is now named *A* instead of *Untitled*. |
