revealmultipleinfinder
PATH
The revealmultipleinfinder statement reveals one or more files or folders in the Finder.
path – is a path to the file or folder to be revealed, including the file or folder name (see Files and Folders for more information about file paths). This parameter may be repeated to reveal multiple items.
This statement reveals one or more documents or applications in the Finder. A new Finder window opens displaying the specified item, with the specified items highlighted. If necessary, multiple Finder windows will be opened so that all of the specified items can be visible. This example will reveal the PDF documents concert-ticket.pdf and movie-ticket.pdf in the Finder.
revealmultipleinfinder "~/downloads/concert-ticket.pdf","~/downloads/movie-ticket.pdf"
In this example three different Finder windows will open, so that all three of these items will be visible even though they are in different folders:
"~/documents/san diego/presentation.keynote",
"~/documents/portland/newpresentation.keynote",
"~/documents/fresno/oldpresentation.keynote"
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- Reveal in Finder -- reveal the location of a database in the Finder.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
