batchreplace
DATA
ARRAY
MAINSEP
SUBSEP
The batchreplace statement performs multiple find and replace operations on a piece of text.
data – Name of the field or variable that contains the text to be changed.
array – Array containing pairs of words or phrases to change and the new words or phrases.
mainsep – Main separator between pairs of values.
subsep – Sub separator between each item within a pair.
This statement performs multiple find and replace operations on a piece of text.
This example replaces any occurences of AZ, CA or OR with Arizona, California, and Oregon, respectively.
batchreplace text,"AZ,Arizona/CA,California/OR,Oregon","/",","
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
