findreplacedialog
The findreplacedialog statement opens the Find & Replace dialog.
This statement opens the Find & Replace dialog, just as if the user had chosen Find & Replace from the Find submenu of the Edit menu.
See Find & Replace Dialog to learn more about this dialog.
10.0UpdatedCarried over from Panorama 6.0, but now allows change to occur across all fields.
