splitmenutrigger
MENUNAME
MENUITEM
The splitmenutrigger statement splits info(“trigger”) into separate menu name and menu item variables.
menuname – will be filled with name of menu that was selected.
menuitem – will be filled with name of menu item.
This statement splits info(“trigger”) into separate menu name and menu item variables.
This example splits the menu trigger into separate items. This would normally be used in the .CustomMenu procedure.
splitmenutrigger menuname,menuitem
