deletewebtemplate
DATABASE
FORM
The deletewebtemplate statement deletes the web template (a dictionary) associated with a form (if any).
database – name of the database that contains the form, or “” for the current database. The specified database must be open
form – name of the form that contains the template.
This statement deletes the web template (a dictionary) associated with a form (if any).
deletewebtemplate "","Sign Up"
Note: Deleting the form will also delete the template (since the form contains the template).
10.2 | Updated | Carried over from Panorama 6.0, but now stores the template in the form itself, and allows a database to be specified. |
