The runmodifyfill statement runs the .ModifyFill procedure (if it exists).
This statement runs the .ModifyFill procedure (if it exists). This statement is used internally by Panorama, but can also be called in user code, like this.
formulafill A+B
runmodifyfill
Note: A procedure can also explictly use the call statement to call .ModifyFill
if you are sure that it exists. The advantage of runmodifyfill is that it will check to make sure that .ModifyFill
exists, and won’t cause an error if it doesn’t exist.
10.1.2 | New | New in this version. |
