makenumberedarray
ARRAY
SEPARATOR
START
END
The makenumberedarray statement generates a numeric sequenced text array.
array – the field or variable where the generated array will be placed.
separator – the separator character.
start – the starting number of the sequence (must be an integer).
end – the ending number of the sequence (must be an integer that is larger than the start value).
This function generates a numeric sequenced array. This example will fill the variable numbers with the sequence 1,2,3.
local numbers
makenumberedarray numbers,",",1,3
This example will fill the variable numbers with the sequence 8,9,10,11,12,13,14,15.
local numbers
makenumberedarray numbers,",",8,15)
