ruby
SOURCE
RESULT
FOLDER
TIMEOUT
The ruby statement executes a Ruby script (program).
source – Ruby script (source code). Note: It is very convenient to use “pipe” delimiters for this parameter, for example |||script|||. This eliminates needing to worry about the delimiters that occur in the script itself.
result – Name of field or variable in which the result of the script will be placed. This result is any output sent to the standard console output. If this parameter is not supplied the result will be placed in the global variable ScriptResult.
folder – Folder to execute perl script in (default to current database folder)
timeout – Maximum amount of time the script will be allowed to run (in seconds). If this option is not specified you can set the default using the scripttimeout statement. If this default has never been set the default is 60 seconds.
This statement executes a Ruby script (program).
local output
ruby |||puts $«Colors»$.split(' ')|||,output
message output
WARNING: Apple has stopped providing Ruby with macOS. If you are using a recent version of macOS, you will have to install Ruby yourself. See Scripting Language Configuration to learn how to do this.
Panorama formulas can be embedded in the script using special tags.
To embed a Panorama text formula use
$«formula»$
The formulas are calculated in advance, then embedded into the source code as constants. For example, the formula $«2*3»$ will be embedded into the program as 6. The formula $«upper("hello world")»$ will be embedded as "HELLO WORLD".
In the case of text formulas any special characters will be encoded as necessary for a proper Ruby constant. For example the formula $«{"}»$ will be embedded as """.
To embed a Panorama formula with no quotes or translation use
^«formula»^
