copynewerfolder
SOURCE
DESTINATION
The copynewerfolder statement copies an entire folder full of files, but only copies newer files.
source – Path of original folder
destination – Path of destination folder
This statement copies an entire folder full of files. However, the files are only copied if they are newer than the old files..
This example copies the contents of the folder New Stuff into the folder Previous Stuff. Files in New Stuff that are older than the corresponding files in Previous Stuff are skipped (which can be a lot faster).
copynewerfolder "~/Documents/New Stuff/","~/Documents/Previous Stuff/"
Monitoring Progress
If the specified folder contains a lot of files that have changed, the copynewerfolder operation can take quite a while. If your procedure contains a copyProgress: label, the subroutine at that label will be called once for every file in the source folder (even if the file has not changed). The subroutine will have one parameter, a dictionary that contains information about the file and how it was handled (more about this dictionary in a moment).
Here is an example that displays the progress of the copynewerfolder operation in the tool bar banner. As the copy proceeds, the banner will fill up like a thermometer (see the setbannerprogressbar statement).
return
copyProgress:
let progress = parameter(1)
let index = getdictionaryvalue(progress,"INDEX")
let count = getdictionaryvalue(progress,"COUNT")
setbannerprogressbar index/count
return
The dictionary passed to this subroutine contains four items:
- COUNT the number of files that will be copied.
- INDEX how many files have been copied so far (1, 2, 3, etc.)
- SOURCEFILE the path and name of the file that was just copied from.
- DESTINATIONFILE the path and name of the file that was just copied to.
- UPDATED how the file was handled, either Identical (if the file has not changed, so doesn’t need to be copied, New File (if the file didn’t exist in the destination before), or Updated File (if the file in the source folder is newer than the version in the destination folder, so needed to be copied).
In addition to being called after each file is copied, it is also called before the copy begins (with a COUNT of the number of files to be copied and an INDEX of 0). It is also called after the copy is finished, with a COUNT of 0 and INDEX of 0.
Warning: The code in the copyProgress: subroutine cannot access or modify any local variables in the main program. If you need a variable to be accessible to this subroutine, you must use a fileglobal, windowglobal or global variable.
Filtering the List of Files
The copynewerfolder statement normally copies all of the files in the folder. You can, however, set up a filter to restrict which files are copied. To do this, set up a subroutine inside the procedure that calls copynewerfolder with the label filterSourceFiles. Before it starts copying files, the copynewerfolder statement will call this subroutine, with the list of files it is about to copy as the parameter. The subroutine can modify the list, then pass it back to the copynewerfolder statement. Here is an example that will copy any PDF files in the New Stuff folder to the Previous Stuff folder.
return
filterSourceFiles:
let sourcefiles = parameter(1)
sourcefiles = arraystrip(arrayfilter(sourcefiles,cr(),
{?(import() endswith ".pdf",import(),"")}),cr())
setparameter 1,sourcefiles
return
Any non-PDF files in the New Stuff folder will be ignored.
| 10.2 | Updated | Now can report progress back to the calling program, and can be programmed to filter the list of files to be copied. Also, this statement actually works now. |
