undefinewindowglobal
VARIABLES
The undefinewindowglobal statement destroys one or more windowglobal variables.
variables – is a list of windowglobal variables to be destroyed. Each variable should be separated from the next by a comma. If a variable name contains spaces or punctuation, or begins with any character except a letter or underscore, it should be surrounded by chevron (« ») characters.
This statement destroys one or more windowglobal variables. The variables may have been created with the windowglobal statement. Destroying a variable completely removes it as if it had never been created in the first place.
The example destroys two variables, Counter and Operating Ratio.
undefinewindowglobal Counter, «Operating Ratio»
You can also use unwindowglobal as a synonym for this statement, like this:
unwindowglobal Counter, «Operating Ratio»
- assignglobal( -- assigns a value to a global variable (creating the variable if necessary).
