enableabort
The enableabort statement allows the SHIFT-COMMAND-ESCAPE key sequence to stop an endless loop.
This statement allows a loop to be stopped early by pressing SHIFT-COMMAND-ESCAPE or by exceeding a maximum loop time. To learn more, see Preventing Endless Loops and also the disableabort statement.
- quit -- quits Panorama.
| 10.2 | Updated | Carried over from Panorama 6.0, but with updated behavior. |
