clearrecord
The clearrecord statement deletes the currently selected record.
This statement removes the entire active record from the database. After deleting the record, all other records below the current record move up one row in the data sheet window and the cursor will reside on the next visible record immediately following the deleted record. On a single record view form the display will change to the next visible record after the deleted record.
This statement will delete the currently active record unless there is only one record selected. You can never delete the last visible record from any Panorama database.
This simple example will remove the active record from the database.
clearrecord
If you want to delete the record and put the deleted record in the clipboard, use the cutrecord statement.
