executecatcherrors
PROGRAM
PARAMETERS
The executecatcherrors statement is the same as the execute statement, except for the fact that if an error occurs while running, it can be trapped by an if error statement immediately following the executecatcherrors statement.
program – is the text (source code) of the program you want to run.
parameters – is a list of parameters to be passed to the subroutine. This list is optional, you don’t have to pass any parameters if you don’t need to. See parameter( and setparameter for more information on accessing parameters within a subroutine.
This statement is the same as the execute statement, but it allows the calling procedure to trap errors with the if error statement. Here is the basics of how this can be used.
local Code
Code = " ... some ... code ... here "
executecatcherrors Code
if error
message "Code runtime error:"+info("error")
Note: We no longer recommend using this statement, instead, use the try and catch statements, like this.
local Code
try
execute Code
catch
endcatch
In fact, the way the executecatcherrors statement works is by simply adding try and catch statements to your code. The program
is exactly equivalent to:
execute "TRY "+Code+" CATCH RETURNERROR INFO("ERROR") ENDCATCH"
- Custom Statements -- creating your own custom statements that can be used in your code.
- parameterentity( -- returns the entity (field or variable) associated with a subroutine parameter, if any.
- setparameter -- is used to transfer data from a subroutine back to the main
10.0 | Updated | Carried over from Panorama 6.0 but now now allows parameters to be passed to and from the subroutine using the param( function and setparameter statement. Also, it is now ok to use executecatcherrors recursively. |
