findnth
NTH
SECOND
The findnth statement finds the nth (2nd, 3rd, 4th, etc.) record that matches a true-false test.
nth – Occurence you want to fine (1, 2, 3, 4, etc.)
second – Formula for true-false test
This statement finds the nth (2nd, 3rd, 4th, etc.) record that matches a true-false test. This example finds the fourth record in the database that contains “surf” in any field.
findnth 4,exportline() contains "surf"
