letwindowglobal
VARIABLE
VALUE
The letwindowglobal statement creates a windowglobal variable and assigns a value to it.
This statement has two  parameters:
variable – is the name of the variable that you want to create.
value – calculates the value that will be placed into the variable.
This statement works just like an assignment, but the destination of the assignment is automatically created as a windowglobal variable. For example, this statement creates a windowglobal variable named pageCount and assigns the value 23 to it.
letwindowglobal pageCount=23
The value can be any data type, for example text like this:
letwindowglobal userName="Bob"
Note: This statement is identical to the assignwindowglobal statement, but letwindowglobal uses an equal sign between the variable name and the value, instead of a comma.
