showrecordcounter
The showrecordcounter statement forces Panorama to redisplay the record counter in all windows in the current database.
This statement tells Panorama to redisplay the record counter in every open window of the current database. (The record counter appears in the tool bar). Use this command after the noshow command when you have added or deleted records.
Here is an example that adds three new records to the database but only updates the display once.
noshow
addrecord
addrecord
addrecord
showpage
showrecordcounter
endnoshow
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- fontcharacters( -- returns a string (text) containing all of the characters supported by the specified font.
- fontinfo( -- returns a dictionary with information about a specified font.
- hide -- temporarily disables the output of text and graphics.
- measuretext( -- returns the size of a string of text in a particular font and size.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- setbannerprogressbar -- displays progress in the toolbar banner.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showline -- forces Panorama to redisplay the current record in all windows in the current database.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
