firstcolumn
The firstcolumn statement moves to the first column in the data sheet (leftmost column).
This statement moves to the first column in the data sheet (leftmost column). This is the same as clicking in the first column, or clicking the First tool in the tool bar. If necessary, the data sheet will scroll to make the first column visible.
firstcolumn
This statement should only be used in data sheet windows.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
