openwith
APPLICATION
PATH
The openwith statement opens a document with a specific application.
application – the name of the application to be launched. This can include the .app suffix, but it doesn’t have to.
path – is a path to the file to be opened, including the file name (see Files and Folders for more information about file paths).
This statement opens a document with a specific application. This has the same effect as dragging the document to the application in the Finder. The first example will open the PDF document concert-ticket.pdf in Preview. The second example will open it in PDFPen.
openwith "Preview","~/downloads/concert-ticket.pdf"
openwith "PDFPen","~/downloads/concert-ticket.pdf"
If you want to open a document with its default application, use the openanything statement.
Legacy File/Folder Syntax
Previous versions of Panorama (version 6 and before) used a folder/file format for specifying files and locations. If you prefer this format, you can add a third parameter to the openwith statement. This example opens an image using Pixelmator.
openwith "Pixelmator",dbsubfolder("Images"),"someimage.png"
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
