loadallprocedures
DICTIONARY
PROCEDURES
The loadallprocedures statement loads all the procedures from a dictionary into the current database.
If a procedure doesn’t exist it will be created.
dictionary – a dictionary containing multiple procedures (built with the SaveAllProcedures statement)
procedures – Field or variable to receive carriage return delimited list of procedures that were actually modified.
This statement loads all the procedures from a dictionary into the current database. If a procedure doesn’t exist it will be created.
LoadAllProcedures myProcedureDict
