arraybuild
ARRAY
SEPARATOR
DATABASE
FORMULA
QUERY
The arraybuild statement builds an array by scanning a database and creating an array element for every record (including invisible records) in the database (see Text Arrays).
This statement has five parameters:
array – is the variable or field that will contain the new array. If you use a field for this parameter it must be a text field.
separator – is the separator character or characters for the output array.
database – is the database that will be scanned. This database must be currently open. If this parameter is "" then the current database will be scanned. Note: The arraybuild( function will scan every record in the database, including records that are not currently selected. If you want to build an array from only selected records, use the arrayselectedbuild( function.
formula – is the formula that will be used to extract data from the database and build each array element. If the formula results in empty text (“”) for a record then no element is added to the array for that record. The formula usually references fields in the database being scanned. It may also use the seq() function to include the number of each record (within the scan).
query – is an optional formula that determines whether a record should be included in the output array. For example, the query formula Price > 100 could be used if you only wanted to include items with a price greater than 100 in the array. The query parameter can be omitted, in which case all records will be included.
This statement creates a Text Array by scanning contents of a database. This statement scans ALL records in the database, whether they are visible or not. If you only want to scan visible (selected) records, use the arrayselectedbuild statement. (This operation is also available as a function, see arraybuild(.)
The first parameter is the name of the field or variable that will contain the generated array, in this example a local variable named Name. The second parameter is the separator between array items. In this example, the separator is two characters, a comma followed by a space. The third parameter is the database name. If the database name is left blank, the current database will be scanned. This example builds a list of all the first names in the database. (Note: If a name appears in the database twice, it will appear in the array twice.)
local Names
arraybuild Names,",","",First
Names ☞ Bob, Sue, Mark, Stan, Ralph
The formula parameter allows you to customize the construction of the array.
local Names
arraybuild Names,",","",upper(First)
Names ☞ BOB, SUE, MARK, STAN, RALPH
You can add a second, optional formula to limit the records that will be included in the output. In this example, only fish that are less than $1.50 will be included in the array.
local Inventory
arraybuild Inventory,", ","Fish Tank",Fish,Price < 1.50
Inventory ☞ Goldfish, Guppy, Neon
This example generates a list of fish that cost more than $30.
local Inventory
arraybuild Inventory,", ","Fish Tank",Fish,Price>30)
Inventory ☞ Boeseman's Rainbowfish,Black Ghost Knifefish,Harlequin Rasbora
Advanced Tip: The arraybuild( function can be used as a super flexibile alternative to the lookupall( function. See lookupall( for examples.
Referencing Fields in the Original Database
Sometimes you may want to reference fields in the current database, especially in the query formula. For example, suppose you have an Invoice database that contains customer names in a Name field, and a Customer database that contains First and Last name fields. This formula can be used in the Customer database to display a list of invoices for the person currently selected in the Customer database.
arraybuild InvoiceList,cr(),"Invoice",
datepattern(Date,"MM-DD-YYYY")+" "+pattern(Total,"$#,.##"),
Name = ««First»»+" "+««Last»»
Notice that the First and Last fields, used in the last line of this example, are enclosed in double chevrons. The use of double chevrons specifies that a field is in the current database, instead of the database that is being scanned. There are three fields referenced in this formula:
Name ☞ in Invoice database
First ☞ in Customer database (because of double chevrons)
Last ☞ in Customer database (because of double chevrons)
The result of this statement will be a list of invoices for the current customer, something like this:
08-14-2014 $3,498.93
09-27-2014 $1,723.05
11-05-2014 $5,381.60
Advanced Note: Internally, Panorama actually converts double chevrons into the fieldvalue( function. So the example above is internally converted into this:
Name = fieldvalue("Customer",First)+" "+fieldvalue("Customer",Last)
The double chevron notation is a convenience, making this formula much easier to write, and to understand.
Error Messages
Assorted error messages – If the formula supplied by the user contains an error, the operation is aborted and the error is returned.
- related( -- searches a database for a record in a related database that matches the current record in the current database based a relational specification (based on one or more key fields or formulas in each database), then uses a formula to return other information from the same record. This is similar to the lookup( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedarray( -- builds an Text Array by scanning a database and creating an array element for every record that matches a relational specification (based on one or more key fields or formulas). This is similar to the arraybuild( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedrecordid( -- returns the record id of a record in a related database that matches the current record in the current database based on a relational specification.
- Relational Workshop -- tool that assists in composing relational lookup(, superlookup(, lookupall( and arraybuild( functions.
| 10.0 | Updated | Carried over from Panorama 6.0, but now includes an optional query formula that can be used to limit the records included in the output. More than one character is now allowed for use as the separator parameter. |
