serverjournalcode
CODE
The serverjournalcode statement writes code to journal file.
code – code to journal.
This statement writes code to the journal file. This example adds a journal line to record changes to the Price field.
serverjournalcode {field Price formulafill 0}
This statement is used internally by ProVUE, but could also be used by web code.
- Web Cookies -- web cookies.
